gas tank / common as leaks
getmoney06
im not sure if this is where to put this but i truck leaks gas mostly when filled up but b4 i go and tear it all apt maybe i guys cant give me some hints
The top of the tank may have rusted a bit, allowing gas to come out when the tank is full. Or a hose could be lose/leaking on the fuel pump. Just isolate the leak area(near engine or fuel tank) and if its near the tank area drop it and look around. Hopefully a weld spot on the tank hasnt come apart and its an easy fix such as a hose or the fuel pump seal.
