While I agree with what Will said...
If you really can't be talked out of wanting to use those tires, here's how to handle it....
Your stock front axle will NOT like those tires. Sure it may last awhile, but trust me, it will go. I toasted the front axle in my choptop on 33's in soupy mud. Loud POP and suddenly I had three spinning an one dragging cuz the YOKE detonated on the shaft (not the new joint, it still had all the caps) and the splines twisted off in the diff. Not pretty.
So, you can either do a bodylift (not the way I'd go because you still really should change axles), or you can go another route....which will leave you better off down the road....
Swap axles, at least the front axle. You'll want a D-35 front from a 4.0L Ranger or from an Explorer. Try for 3.73 or 4.10 gears. Snag a set of springs from a 4-door Explorer, coils and leafs. Put the springs in with the axle(s). Trim fenders for remainder of clearance and get an alignment.
If you take your time looking, this could easily be done for less than $400 at most, if you try to rush it, it's gonna cost more.
But the real problem is that it's your DD, which means that if you tear the suspension apart, and something goes wrong on gettin it back together (as anyone will tell you often happens, nothin like the 10pm sunday night "OH FAWK!! NOW how do I get to work??"), then you're in trouble.
