Gas mileage 460 vs 351m
I think the 351w is a wonderful engine... in a Mustang or ranger with someone who undrstands that
revving it is a bad idea.
a 351 is to a 302 EXACTLY as a 4.0 is to a 2.9
a 460 built to about the same performance level will generally get better mileage
because to produce the same power it'll generally be spinning at about HALF the rpm.
My brother through careful setup managed to get his 1989 F250 with a 351W engine to get a fairly consistant 16-17mpg on the highway, otoh the 460(EFI) he replaced it with could usually do 18-19 on the identical (repeated) trip.
but when it came time to tow something the 351w had NOTHING when compared to the 460.... it came as no suprise that towing anything he ever tried ever knocked down the mileage of that 460 below ~14mpg
I say go with the 460, it's simply a better engine.
Hell, I have an idea of putting a 460 into '92-is F-150 with ~3.08 or 3.55 gears
the idea being that grinding across nebraska in 5th gear with the engine turning over
~1600rpm... not built for power, but minimizing the operating rpm in cruise.
it takes about 85-90 road hp to keep an F-150 rolling at 70mph the engine that can do that at the lowest rpm wins.
And the only real competetion to a 460 set up "correctly" is a 4.9 inline 6cyl, but I know from
experience that one of those isn't a whole lot of fun driving westbound across nebraska into
a 30mph headwind.
But I was also going to run it on the MAF EFI system robbed off a 1995 5.8
and since the 460engine I already have has flat top pistons in it, with the EFI heads
the compression will be "up there"
high compression, low rpm
Generally speaking the largest practical engine when geared to allow low rpm operation will usually get the best economy.
It should be noted that while all the people who really know me KNOW "Agressive" is an understatement,
yet I've always been the one who winds up in the drivers seat of "their baby", especially
when getting either the maximum ammount of miles behind the receiver hitch OR towing
something heavy and/or not arriving in an ambulance are the goals of a trip.
AD
Allan remember the lowest rpm in theory is nice for mileage, but you dont wanna bog it either, carbed or fuel injected the air/fuel ratio leans out higher in hte rpm range, so a truck with 460 cruising at 1200 rpms at 70 and a truck with 460 cruising at 1800 rpms at 70. The truck with 1800 rpms will have the slightly better mileage. Its a balance thing as well. But your right about the bigger engine having better mileage just dont go too low in the rpms.
It's a 79 F150 he's putting this thing into- screw mileage! It's like a brick sh*t house going down the road. What's wrong with your 351M? If nothing than I'd just spend money on upgrading it instead of starting over with another engine. My brother did a stroker kit on his 351M, milled the heads, cammed it, stall convertor in the C6 and that truck would roast all 4 tires (35" ground hawgs + 4 low) on dry pavement.
Mileage out of a big block? That's like taking the noise out of a Harley v-twin.:beer:
My milage went down in my F-150 when I lowered my rpms, with my tiny stock tires I could just about hit 20mpg pretty easy. Now 16 is the norm. Putts down the road at 1400 rpms and downshifts on almost every hill with the cruise on.
And what size tires did you go to without re-gearing?
if i were you id keep the 351M. it will be just as good on gas or better, and unless your looking for a shit load of hp your wasting your time and effort. alot of people bash the 351m but i love mine and would not trade it for a 460 for the world
your kidding right? my 351m will tear up a 351w like a freakin 2.9 lol
Come on down big guy............My little F-100 will be waiting on ya!
Just yanking your chain Boggin.........dont get you knickers in a twist....lol.
235/70-16's to 255/75-17's with 3.31 gears. It still drives fine, but regearing to 3.73's in the works. My Ranger needs an engine worse. So until then, the stock wheels with more stock sized tires (255/70-16's) get swapped on when I need to pull something.
I snagged the wheels with 265/70-17's cheap and thought I would give them a whirl figuring if I didn't like it I could turn around and sell them for a profit. They were not that bad, and I found a set of new tires cheaper than I could find a set of 16's so they stayed. I don't drive on the highway much anymore, so the decreased hwy milage isn't a big deal for me.
It is an extreme case, but shows that the lowest possible rpm doesn't always yield the best milage.
haha, im sure yours is running a bit better than the one i tried
Every engine has it's "happy zone"
I can say that an F-150 with a 4.9, 5sp & 3.08's will NOT get as good mileage as the same truck after you regear it to 3.55's.
That is presuming stock or close tires.
an F250 with the same combo and stock 235/85-16's 3.55's is too much gear, it needs 4.10's.
The point of the big engine is all about reserve torque and in terms of "happy zone" the 300/4.9 and
the 460/7.5 are remarkably similar in their best mileage rpm band.
I'm still looking for the proper body and frame. Ideally a 1992-95 F-150 supercab "glider"
(No (or dead) engine and trans)
I'm pretty much convinced that I can hid 100gallons of fuel tank in it without counting
my (commercially made) 70gallon in-bed tank
AD
