Fuse 26
IRON WOLF
Virginia
I have a 2000 ford ranger I noticed my noise for when I leave my key in the ignition was not work I look in fuse box on the drivers side and my 10 amp fuse (#26) was blown I replaced it’s and it blew again truck was not started I just hooked up my driver side speaker I unplugged my radio and put another fuse in today and it blew I don’t what to or where to start
fuse 26 powers:
battery saver relay
electronic shift relay
interior lamp relay
electronic shift control module
instrument illumination dimming module
interior/map lamp
gem
instrument cluster
procedure would be to unplug/disconnect as many of those as possible then put a fuse back in.
if you're good with a meter check the resistance first.
