Fully fixing the b series
sbsumerix
Pullman, MI
Im home for spring break from college soi decided its a good time to do all the repairs needed. first off today i replaced the passenger cab mount pretty easy took about an hour and it all came apart suprisingly easy considerig the rust. Tomorow is the fun part with the driver side seeing how the gas tank is in the way i know i could remove it but i dont feel like it. also i have to fix my exhaust where it comes out after the cat and has an odd flange to hold the system together it was never there when i bought it so rigged it up to complete the system should be welding in a new peice of pipe to repair it. found my passenger ball joints are bad should of just replaced them when i did the drivers side last year. do you need a special tool to remove the joints i did when i did it at school but i dont have one here at home. next problem is a cracked tank for the radiator should be an easy fix with some epoxy i think. final problem is the seal where the pitman arm comes out of the steering gear box is leaking. do you have to remove the gear box to replace the seal or can it be done with it al intact?
