jarfly
- Oct 7, 2007
- Age
- 34
Looking for some advice on doing the full size bronco swap on my 97 reg cab truck.Just seems easier & more budget friendly. not dealing with making motor mounts for my 351, exhaust seems a lot easier to deal with.
My only fought to the swap is the cab setting high.this would not be much of a problem if I had 38s or so but just on 34"s atm.
By looking at some pics i'v found on the inter web looks like I may be able to cut the mount on the cab a bit to have it set a bit lower? Also I know the wb is a bit shorter, just may leave that as is see how it does. if not wont be to hard to make it a bit longer. Any how thanks for the advice on cutting the cab mount down, and any more things i should look out for with this swap.
and just to be a bit more clear, the part that bolts go through on cab is what i'm wanting to cut to try to get lower. I know i'll have to come up with some how to reinforce it.
