Full-body bilstein 5100 front shocks for a 2wd Edge
I’m on the fence too with my 05 edge trim. I have my suspension leveled out with the back currently and want to know if the 4600s will be sufficient. But I’m confused about “stock ride height” comments when I assuming everyone’s referring to the non- torsion bar suspension/ FX4 set ups. Will the 5100s be preferred on a torsion bar suspension?
Assuming your edge is torsion bar front end set up since you have an edge.
What I did : I have a 1.5-2” lift so I put on KYB mono tubes(OEM spec which is about 18” extended) and added in 1.5” spacers to make up for that space.
What I wish I did : purchase these bilstein 5100s (24-185684) and put in a bar pins myself so it would be plug n play without spacers.
If yours is lifted I would not recommend to put in the 4600s (24-188241) since they aren’t long enough.
