fuel system question
HndMeDnBroncoII
Ford Technician
Pitt Meadows
hi guys i have an 88 BII with 2.9l efi
for quite a while now and periodically the truck takes a while to start
most often the truck starts right away.I have replaced the pump in the tank
the fuel filter and the fuel pressure regulator and the fuel pump relay the ground wires at the battery .If i cycle the key a couple of times it will start right away,so i assume the pressure is bleeding down.
So no im stuck can the injectors be seeping.
Any ideas would be greatly appreciated.
Yes it is possible for an injector to leak down while sitting for a while.
