Fuel supply
acidh3r3t1c
Des Moines Iowa
Im getting close to finished with my v8 swap and im now onto fuel line and supply i have ordered lines and fitting to go from my fuel rail back to the tank. My swap in on an 88 ranger so it has the two pump system. I want to go to a one pump system hopefully an in the tank pump. What I'm wondering is what I have for options for an in tank pump that will supply fuel for a 91 HO 5.0L no additional performance parts added and what adapters i can get to go from the sending unit/pump assembly to connect to -an fitting on my new fuel line. I'm using -8an fuel line but if you know of adapters that are a different size i can always use a reducer or expander.
2 pump system? Not familiar with that one, since mine is a '92. I don't know if it helps or not, but I simply swapped the fuel pump from a 5.0 mustang. Here's what I am using now: http://www.summitracing.com/parts/BBK-1607/?rtype=10
Yours is probably going to be different than mine, and I am not sure what other people are using for the first gen EFI swaps.
