pearldrumbum
OK, so i found an '84 ranger down the road that a guy wants to sell. Im thinking about buying it and putting the 2.3t im building in that instead of my DD, mostly because my DD has never done anything to deserve a transplant (that's a good thing), and i know i'll probably spend some time after the swap working out kinks...
my question is, the 84 is carb'd now, so it doesnt have a fuel return. What's the best way to get around this? swap the tank? Or will a simple ebay fpr work? I'm assuming that if it's designed to just bleed off extra gas, then the amount of fuel that's needed varies (that's actually obvious anyways)....
so, is there a regulator that will work so i can just block the return line, or should i just swap tanks?
