Simkins12
1990 with the 4.0L. Checked other threads regarding this issue and did what they said in terms of troubleshooting and/or replacing the part. Ranger still does not start.
A little history:
I changed plugs & wires (Motorcraft and gapped correctly); changed fuel filter all about 4 months ago. Ranger was running great, no starting issues, no rough idle or it cutting out.
About a month ago, the Ranger got harder and harder to start. I could start it, but after trying many many times. Once it was running it was fine. I could shut if off and then come back and it would fire up.
Finally got to a point where it will crank and crank but not start. So I started listening for the whirring of the fuel pump...I heard it but it sounded weak.
What I have done so far:
-New fuel pump (complete hanger assembly with strainer)
-Checked that I do have spark at each of the cylinders
-No burned or frayed wires or bad spark plugs
-Gap on spark plugs is set to factory specs
-Battery terminals and battery are good and clean
-No Inertia Switch; it was removed and bypassed by previous owner; wiring and connection is tight and making contact
-Replaced fuel pump relay
-Fuel pump relay fuse is good and new
-Plenty of fuel in the tank
-Cleaned/inspected IAC
After all of this, engine cranks but does not start
With the new fuel pump relay and new pump, it is not coming on at all. I am not getting fire at the fuel pump harness connector.
This definitely seems like electrical, where else can I check between the fuel pump relay and the fuel pump?
Can the system be OPEN? It just seems that the issue kept deteriorating rather than an all out fail of a part.
Any help is greatly appreciated.
A little history:
