Kobalt Silvertail
Hi i have a 94 Ford Ranger 4x4 Manual 4.0L splash and my fuel pump wont shut off. we hooked up the fuel pressure gauge and it reads 32 psi I was told by ford operating psi was 40, I changed plugs, wires, relays, fuses, fuel pump, fuel filter, and fuel pressure regulator. It still wont stop running. I have to cycle the key and it takes me about an hour to start it. I just received new injectors in the mail. I keep hearing a hissing noise from them. does that mean they are stuck open and dumping gas? it burns so rich it burns your eves if you stand around the truck to long. what should i do?
