bobaloo
Sometimes when I try to start my truck the fuel pump doesn't run. But if I just sit and turn the ignition on and off several times I will eventually hear the pump "run" and it will start and run fine. If the pump itself was bad, wouldn't it cut out while driving? This problem only happens at start up and occaisionally. Sometimes it will be fine for a month or so, then act up again.
I don't want to get stranded with a bad pump. I hope it's just a solnoid or contact problem.
While I'm here, what is the O.D & I.D of the stock exhaust on a '94 2.3? Someone stole my cat. conv. Grrrr.
TIA
TIA
