fatt_owl2.9
- Oct 8, 2008
for the almost 2 years I've had my truck, it's had an intermittent problem with the frame rail pump not engaging every time I turned the key. It would come and go, sometimes be really bad, and then sometimes disappear for quite a while. Finally a couple months ago I was having some other work done on the truck, and the mechanic (who is really good, and I trust) couldn't get her started at all, and he recommended we replace the pump, which I did. I haven't had any problems with it starting since, but every now and then it will just die in the middle of traffic, but usually starts right back up with no trouble.
well, last night it died in traffic, and no matter what I did, would not start again. That fuel pump will not cycle no matter what. Towed it home, went out this morning, and the pump still won't come on. Is the FP relay the next thing I should be replacing? I'm gonna scream if it's something like the ECU. I'd also wanna replace the inertia switch, but the general consensus seems to be that those seldom to never go bad. Also, where is the fuel pump relay located? Thanks in advance for any advice guys, have a good one
