Fuel pump question
Trevorrudai
Idaho
Hi I am wondering will direct wiring a fuel pump to a toggle switch directly to 12 volts cause a decrease in gas mileage? I have recently done this on my 2.9 and not only does it seem like I'm getting half the gas mileage that I was before I can also clearly hear my high pressure fuel pump just underneath the driver's floorboard running the entire time it's on, EVEN over the motor running, which was not the case whatsoever before I hotwired it. Does the fuel pump relay possibly reduce amperage or voltage being sent to the fuel pump? I'm just confused at why I have such a substantial decrease in my fuel mileage when all I did was hotwire the fuel pump. Anybody has any knowledge behind this please let me know I can easily wire it back up to the inertia switch which I intend to do regardless however if this is the cause it will definitely be moved to the top of my priority list thank you
When engine is running the fuel pump(s) always got system voltage all the time, its only when key is off or engine is off that the fuel pump(s) don't get power
The engine computer controls a Fuel Pump relay, and that sends system voltage to the fuel pump(s)
So its on or off there is no cycling or other control for the fuel pump electrics
This is the same for all fuel injected Ford Rangers 1986 to 2011
So a fuel pump on/off switch wouldn't change anything
In a 2.9l there would be a Return fuel line, maybe yours is leaking at the top of the tank, with engine off and switch on this would pump out more fuel than if the computer controlled relay was being used because pump would be off until engine started
"System Voltage"
When engine is off the battery voltage is system voltage, 12.3volts to 12.8volts
When engine is running the Alternator provides ALL the voltage, 13.5volts to 14.8volts, and this is system voltage
Maybe your alternator is putting out too much voltage, should be 14.2-14.8 just after startup, then after 5 minutes of recharging battery it should drop under 14volts, if it stays over 14 volts it WILL COOK YOUR BATTERY, period
Ford did start using "fuel pump driver modules" starting in the early 2000's on some models, but not on Rangers
Driver modules would cycle power to fuel pump and often failed, lol
Understood. Thanks Ron. I will have to keep troubleshooting other potential causes for my loss of fuel mileage evidently.
