Fuel pump question
Bronco289
Montana
Hi all, I am brand new here. When I check the voltage for the fuel pump on my 1989 B2 stock 2.9L I see 12.05 volts for about 3 seconds, and then it reads 6.77 volts. This is right on the connector that plugs in on the tank. The connector is unplugged from the fuel pump, and I'm not cranking the engine. Is the 6.77 volt reading normal? Any info would be appreciated.
That is normal to high.
Fuel system functions like this:
Key on, computer commands the pump on for 3 to 5 seconds to prime and then shuts them off. After the priming the pump is run off of the pip signal for the ignition system. That way if the engine stalls due to lack of fuel (such as a ruptured fuel line) the fuel pump will shut off.
Thank you for the information adsm08 it really helped. I am nearly to the point of gassing the B2 up and seeing if it will fire up.
