Bill59
- Apr 18, 2010
I need some suggestions about a fuel problem I'm having. Most of the time when I turn the key, I can hear the fuel pump run for 1-2 seconds and the engine will start. Other times, the pump runs continuously and the engine won't start. I tried a fuel pressure tester on the fuel rail and found that it took awhile to build pressure, so I replaced the fuel filter, which didn't help. When releasing pressure with the tester, I sometimes get air, along with gas coming out of the line, which usually solves my problem. What would cause air to get into the system? Any suggestions? I'm tired of getting stranded!
