fuel pump problem
hickey
New to the forum so..hello
I posted in the wrong forum accidentally but heres the issue. I have a 91 3.0 and it was intermittently not starting. Now it won't at all. I replaced two of the relays that I believe are the eec and fuel pump relays. I got 12v constant to the black wire at fuel pump relay. I have 12v when switch is on to red wire at relay. The double green wire that goes to inertia switch has no power. The Haynes manual I have sucks and only gives wiring up to 90 model. I may not even be checking the correct wires. The other issue is that I don't have a ground or 12v at pump even when I jump the relay to supply power to the pink w/black wire that goes to the pump. Sorry for such a long post but figured I should try to be somewhat clear if I want help.
Thanks in advance and again..hello
I forgot to mention when it did run and I turned on the wipers, the engine would die. I am completely stumped.
