BondoNow I hear no pump...... I could hear it before. Dammit
The relay is the green one? If so, switching it out did nothing.
i have a couple ?s
Put my pressure gage om the shader connection and have 32 psi. When I revit it drops around half a pound the I let off. It goes to 35 psi for a second and back to 32. I drove around the neighborhood. I ran ok and I ju,ped on it and it ran good there too. I am hearing this noise from under the truck that sounds like "tinking" if the makes any sence? I drive it and it will drop off for less than a second and back to normal running condition. Gotta go climb under the truck to find where the niose is comming from?
Where is the module for the transmission located? Does it have a metal vacuum line and where does it start. Im thinking the noise that I am hearing could the vacuum modukator going to the transmission. It tested all the fuel pressure and it all is good.
I think that I have it narrowed to the pump in the tank. When it got down 3/4 of a tank the noise sounded like a house fan hitting the cover. My book says to pull the tank but I have heard other people say its better and faster to remove the bed? The fuel gage float sank over a year ago. I hate to go thru all that work just to clean the strainer and I dont think that the pump would make noise it the strainer was clogged? Ebay looks like the best price for a complete unit?
