fuel pump help please
hddave1
kentucky
im at the point in my v8 swap that i need to concider a fuel pump..i know alot of ppl run ele. but i would rather run a machanical fuel pump..the tech page say to use 1970-1973 Ford Econoline van with power steering..so i looked it up at autozone and this is what i see..... http://www.autozone.com/autozone/pa...193052_0_0_3492&vehicleIdForService=144341084 ....is this correct...now the 302 i have has a block off plate installed where the pump used to be...i didnt put it there so when i pull it off to install the pump, should there be a rod in there or should there be a fuel pump excintric on the cam..i just want to make sure that i have what is needed in the block to use the mech. pump..thanks
Mine had the hole filled in originally and it still had the eccentric on the cam to run a pump. The pump has a lever that goes in there and runs on the essenctric.
A mechanical pump of any sort wouldn't work on my setup, it would either hit the steering box or the powersteering pump/alternator. I put a $45 Mr Gasket inline pump on the frame rail (on an inertia kill switch and a toggle switch)
dont know much about ele. fuel pumps and the inertia kill switch .. you might have to coach me on this setup...that was why i wanted to use a mech fp
My inerta kill switch is out of a '88 Ranger. It just has two wires, one that goes to keyed power and the other I ran to a toggle switch (on/off) and then to the power wire on the pump. My pump is mounted to the frame, so I just grounded it there.
The hardest part of the whole deal was cramming the barb fittings in the nylon fuel line.
I found tha the clamp part of a flair tool( the part that fits around the metal line) can be used to hold the nylon line when forceing the barbed fitting in to avoid kinking the line.
and this inerta kill switch kills the ele. pump in case of emergency..why did you wire to a toggle? why not just the key on power? not trying to be an ass but just trying to understand what your doing so i understand what im gonna do..im not gonna find a 88 ranger around here as far as junk yards go so where is it located in the 88 and can i rob one from another car/truck or can i just go buy a switch...but if i where to decide to go with a mech. pump could i remove the block off plate and reach my finger in there and feel the eccentric on the cam..
Because on my truck the key doesn't have an ACC position, so if I am sitting somewhere waiting for someone I don't have to worry at all of the pump overrunning the carb as I listen to the radio.
I also just like being able to control something like that.
The inertia switch is up on the passenger side floorboard above the carpet, it has a white reset button on top. Just about all efi RBVs have one in one shape or another in that area (at least first and second gens do)
The essentric is a round thing on the end of the cam, I think it also doubles as an oil slinger. You should have it, but check to make sure your FEAD will work with the pump.
ok..lol..im dumb but what is a FEAD
Front
Accessory
Drive
Basically it is your belt setup; crankshaft, water pump, power steering, alternator. On mine the power steering and alternator sit right where the inverted pump would go.
my power steering is on the driver side and the alternator is on the pass. side...looks like i have plenty of room as long as the gas lines hook up at top not at the bottom where the steering box is.. im running 2 v belts
Next time use an electric heat gun to soften the plastic line.
I pulled a entire tank out of an 87 for my 84. I replaced the intank fuel pump with a new one(low pressure for that year) and a inline fuel pressure regulator (running a Rochester QuadraJet) . Might not be an option for you, but might be an option sometime down the road
i went ahead and got a inline ele. fuel pump and its mounted and wired up but im going back and tie in a inertia kill switch as soon as i find one...thanks guys for all the advice
