area51js1
- Oct 15, 2007
- Automatic
I am having a fuel problem...again. I replaced the low pressure pump in the tank and everything was working fine for a while, but now it won't start. If I prime with starter fluid, it starts but will barely idle (really low rpm) although if I slowly give it gas, I can bring the rpms up and it will continue to run as long as I give it gas. Fuel pressure is 40 - 41 psi and holds steady but when I turn the key on and the high pressure pump kicks in, it never shuts off even after the pressure stabilizes at 41 psi. Anybody have any ideas?
