fuel presure
just truckn
suburbs of philadelphia
2.9 V6
6inch suspension 3inch body
hey guys i have a 90 rang 2.9 i just put new injectors in last week and i was just seeing if you guys think im good with the pres key on the pres is 38lbs running its 32lbs iknow its should be 40 at key on and it should drop a little dose this sound ok my engine has a loopy idle and i am just trying to find the problem thanks
that fuel pressure is fine. 32PSI @ idle is good.
fuel press
thanks holyford i just needed to know that it was good i can check that one of my list .
