ropinwillie
What should the fuel pressure be when you check it and if you don't mind telling me how to check it that would be great. I'm not a complete dumbass when it comes to working on it but this is my first Ford v6
1998 and up Rangers use 55-60psi fuel pressure and no RETURN line, FPR is inside the gas tank with fuel pump
Damnit Ron, now you tell me...
Just had the tank out, didn't know there was a regulator in there.
Got a part number for one for 2011?![]()
Yep yep. Saw that little guy right there.... Thought to myself "nawww who would do something like that?"Not a "sold separate" part as far as I know, its on the fuel pump assembly, seen here: https://images.carid.com/tyc/fuel-pumps/150313.jpg
It's the round disc on right side of the unit
It's connected to the "return" line on the fuel filter, the 3rd port on the filter is a Return line: https://ic.carid.com/fram/items/g9343_6.jpg
So. Say I knew this guy that just changed the actual pump, and re used everything else.
And put a 340lph pump back in said factory jig
I UNDERSTAND THINGS NOW1998 to 2011 are "returnless" except they are not really, lol, they just have the return line at the filter instead of at the fuel rail where it was, WITH the FPR, from 1985 to 1997
That also explains why the back side of the fuel filter has two nipples.
