Can't conclusively say.
You could have no vaccum pressure TO the FPR, which would make it run exactly the same. Can you feel vaccum pulling at the line you disconnected?
It also makes me think the root of your entire problem may be a vaccum leak AFFECTING the FPR. I say this because it made no difference that you CREATED a vaccum leak by leaving the line off the FPR, uncapped. Follow me?
The definitive test is to read the fuel pressure at idle, then watch it change as you go WOT (briefly), fuel pressure should increase with throttle application, decrease at idle.
John, it appears that you have been wrestling with this issue since February?
Are your heater controls working?
If you shut the truck off, wait a minute, then select different heat/vent settings, can you hear the dampers move?
Most times, when the FPR fails, fuel pressure stays too high, poor idle, soot in exhaust from running rich, poor fuel economy, etc results.
