cruby
- May 10, 2008
I have an '89 Ranger w/ 2.9 v6 w/ roughly 275K miles + 1 rebuild. Lately noticed loss of fuel pressure after sitting overnight. KOEO several times & can hear fuel pump run, then engine will start. I replaced fuel regulator & fuel filter & it now works OK. Truck still doesn't seems to run right, even before these changes. Hesitates & boggs down a bit on acceleration under load. I know it's old, but not dead yet. I got a fuel pressure gage & checked pressure while engine running & pressure at the injector manifold schrader valve is 29 psi w/ vacuum line attached. 35 psi w/o vacuum line. My Haynes says fuel pump pressure should be 30-40 psi, so it's a little below spec.
I've owned truck since new, and the fuel injectors & fuel pump have never been changed. I reused them on my rebuild.
So my questions are:
Is the 30-40 psi pressure spec for pressure measured at the fuel manifold, or is it at the pump exit?
Is the 29 psi indication that fuel pump needs replacing?
CRuby
CRuby
