Fuel line replacement.
richard booth
Tacoma wa
Question is, what are the connectors for my 88 B2 fuel system named? I am going to replace the old plastic lines and do away w the hi pressure pump and run a intank pump and I want to get the fittings that will fit correctly. Thanks.
Rangers use Nylon fuel lines 5/16th
Ford used Bundy Type fuel line connectors, AKA Quick connect/disconnect fittings, although that name is VERY misleading, lol
Dorman has replacement fittings
While the hose will be 5/16th the connectors can be 5/16th OR 3/8ths
Unless someone has done a 1988 Ranger/B2 recently and knows the size at each connection you need to see if you can find old posts that have it
