Fuel line from pump to fuel rail 1999 mazda b2500
chuck ray
Can you repair the fitting on the pump after you cut in half the rubber hose?are buy a new gas line from pump to engine?
1999 will use 70psi pressure.
Yes, use a barbed connector and hose clamps
Do you think its safe to use the dorman kit
Don't know what "the dorman kit" is, but dorman makes good parts, so sure
800-054
800-054
800-054
SHARE:
5/16 In. Quick Connector, Straight w/ 18 In. of 3/8 In. Nylon Tube and a Union
Application Summary: Ford 2003-83, Lincoln 2002-83, Mercury 2003-83, Merkur 1989-85
Good to know. I got lucky when I replaced the fuel filter on the Rat. Old BMW fuel filters with push on nipples and buck an inch fuel injection rated hose were being contemplated, when lo and behold, the crappy looking connector worked like new. :D
