Fuel line fitings
farmer
Rochester, NH
Mix of 78-96
13ish
39.5x15.5
when i replaced my sending unit the lines leaked like a bastard. so i put new orings on and i thought that solved the problem. well now its leaking again, I've yet to pull the bed off again but I'll assume it those damn fittings, whats the trick to these things? its my 94 and has the plastic clip that goes on the slip on fitting. i really dont want to drop $40 on the two rubber lines but if i have to...
ok so got it apart, and the o-ring is fubar. took it out in pieces. it is the 3/8 feed line, what size o-ring does this need? because its in pieces i can't match it to anything. the steel line is .372, about 3/8. and do i need anything special because of the pressure?:icon_confused:
