babydumpling
- Feb 12, 2013
- Automatic
Hello new at this so wish me luck. I have a 96 Ranger regular cab,3.0 with auto trans. Fuel gauge stays on empty at all times, thinking it is the sending unit float. The manual shows the Yellow/White wire going from send unit to cluster. Was going to put a ground into it at the 16 pin connector in front of tank on inside of left frame rail. My thought was that the ground would send the gauge to full like we use to test in the old days. When I split the connector apart the gauge went to full with the key on . I did not have to ground the yel/wht wire. Am I thinking right that it is in the sending unit and the gauge is ok? Or is there another way to do this testing? Thank You, Andy D.
