- Mar 6, 2020
- State - Country
- MI - USA
- Vehicle
- Ford Ranger
- 4.0 V6
- Automatic
- Total Lift
- 1-1/2 inch front leveling
- Total Drop
- Stock
- Tire Size
- 31/10.50/15
- My credo
- What's the worst that could happen?
There are a ton of how to's on replacing your fuel filter. Here's another one for the 4.0L OHV in a 94 Ranger Splash 4x4. I'm sure it covers a bunch of other models too. I just thought as long as I was gonna do it, I would post some images and note any difficulties. There really were none to speak of though. I was worried about gas spewing out all over the place -- me included -- but it was not bad at all. A few drops and that was it.
Basically, just disconnect the bracket holding the filter into the frame channel. That allows you to move the filter around to access the circle clamp that secured the filter to the bracket. Once the clamp is disconnected you can remove the bracket for full access to the filter. Next, I removed the plastic clip that secured the inlet line to the filter ( most likely you'll remove them in two pieces). Some fuel will start to drip out, I just grabbed it with a rag and secured it up toward the floor pan - no more fuel leaking out. I used one of the rubber caps from the new filter to cap off the old filter inlet line, so no fuel leaks there. Then remove the outlet line. Surprisingly, no fuel leaks there. Then just reinstall in the reverse order. A lot less messy that I thought it would be. Hope this helps someone.
