front wheeles
97ranger19
anyone have any ideas how to straighten up my front wheeles they are runnin on the inside of the tires i heard ball joints could cause this before... it is a 1997 4x4 4.0 leader ranger...
ball joints are gone, and/or needs camber bushings/an alignment.
weak or broken front springs could be a problem too. replace anything broken or worn, then take it in for an alignment
Check you upper ball joints and your tie rod ends. Replace anything you find that is worn out and thin like Kunar said, head on down to the tire shop to get the front end aligned.
