front tow hooks
stomper97
zionsville pa
not sure if this is the right forum but does anyone have a good idea for tow hook mounts on the front of a 97 with the crush frame also how do you reenforce the crush frame so you dont strech it
I bolted 3/8th inch plate along the inside of the frame then doubled up the plate where I bolted the tow hooks on. I pulled a stuck semi (single axle day cab with an empty trailer) out with it and it held up fine.
hick
check out the tec' page, it gives a run down on mounting tow hooks to our style trucks
