Front rotor replacement
k9rem
I have a question (and please forgive my noob status to Rangers). I have a 2001 Ranger Edge Supercab, 2wd, 4 Wheel ABS, and am needing to replace the rotors (and of course the pads). I still need to determine the size of rotors on there.
My real question is do I have to replace the rotors and hubs at the same time? At the local auto parts stores (and some of the online ones) there seems to be lots of rotor/hub combinations as options, but not a whole lot of just rotors.
I have changed rotors/pads for more years than I can count, I also know each model can have it's own "uniqueness" so any advice would be greatly appreciated.
Thanks!
if you need to replace the rotor and the hub is part of it, buy new seals for the back side you may be able to repack and re-use your old bearings, your thinking too much about this, you got it man, you'll be done in no time
