front pads
LOL. The better answer is the 94 and older trucks use a single piston caliper (pad ex. MX249) and the 95 and newer trucks use a 2 piston caliper (pad ex. MX652). The mounting points are different. Do you have 94 pads and an 01 truck? If so you may try and see if the parts store that sells the exact brand of pad you have will swap for the correct one. If not try the Garage Sale section of this site.
Hope this helps.
