Front driveshaft help!
ReD-rAnGeR
missouri
ok, so i replaced my clutch and put transefer case back in and the stupid cv/prop end of the driveshaft will not go back into the tcase. i took the bolts out and the boot end popped loose along with the bearings my question is, is there a certain way to align the ball bearings on the shaft or in the tcase? also, is there a way to completely remove the bowl shaped thing from the tcase? pictures would help thanks.
