RideKTM88
I have a 2004 Ford Ranger, with an 4x4 on the fly, as they call it. When in 4 wheel High OR Low, the front differential Disengages Randomly? Its a problem that has Progressively gotten worse. While in the RPM's and it disengages it sounds HORRIBLE, when it disengages at a low RPM it sounds like gears slipping......... Im not exactly a mechanic but I understand that my hubs and differential are at all times are moving/spinning even in 2 wheel drive up until the transfer case. When engaged my electronic actuator works properly until it randomly disengages?????? Any Help Would Be Greatly Appreciated.
If you'd rather call than type my number is (407) 718-9209
Thanks -Ryan
Thanks -Ryan
