Knight
- Oct 27, 2007
- Age
- 46
- Automatic
I wondering if the front diff is the same between ford rangers and explorers? The reason I ask is I would like to put this in
Ford Explorer 4WD front Quaife ATB differential
Product code: QDF37Z
Catalogue Page: 9
£550.00 (Unit price exc. VAT)
http://www.quaife.co.uk/shop_files/QDF37Z15785.jpg
Quaife ATB differential for Ford Explorer 4WD front is suitable for Ford Explorer 4WD. A direct replacement for the standard Ford open differential, the Quaife ATB differential transforms your car's performance.
Unlike a conventional plate-style limited slip differential, the Ford Explorer 4WD front Quaife ATB differential relies on gears rather than clutch plates for its operation. That means it is much smoother in operation.
The Ford Explorer 4WD front Quaife ATB differential never locks harshly with a set pre-load of wheel slip across the driven axle, like a conventional LSD. Rather, the Ford Explorer 4WD front Quaife ATB differential automatically biases the torque away from the spinning wheel across the axle, to a constantly varying degree, and never locks.
The Ford Explorer 4WD front Quaife ATB differential has many benefits over a standard open differential, including maximising traction and minimizing wheelspin, eliminating torque steer and snatching in front wheel drive cars compared to conventional LSD units, and a maintenance-free design which retains the standard oil lubrication.
The Ford Explorer 4WD front Quaife ATB differential is proven in circuit and drag racing, rallying and road use, and is produced from Corus steel billets, and is CAD designed and CNC machined, then inspected to ISO 9001 standards.
With over 170 applications, the Quaife ATB differential is second to none. Accept no imitations!
Quaife ATB differentials are used by Ford, General Motors and Daimler-Chrysler as original equipment.
The Quaife ATB differential for Ford Explorer 4WD front is also now subject to a lifetime warranty (subject to terms and conditions).
Please confirm your application using the attached techncial drawing.
Catalogue Page: 9
