runnert
My seal has a leak when I am going in 4wd. I got the seal to replace it, but the problem is removing the front drive shaft. There are 4 bolts holding the front "U" joint together. The bolts have no room on the inside (probably from heavy rust) between the hex head and the bracket. Both ends of the shaft are the same. Am I going to have to drill off the heads or is there an easier way?
runnert
runnert
