front diff in a 1992 ranger tips?
kadhare
any tips on how to rebuild it all the gears are out and its just a houseing
there should be a master install kit that will give you some of what you need but the bearing as and seals you will prollyh ave to get from napa
The front of those dana 35 gear section just drops out it's called a pig.If your going to run stock gearing get another whole unit from a junk yard the same ratio and put it in.That way you don't have to set up the gears or anything save a ton of time and money.
