ff_welch
I have discovered my CV Shafts or joints to be bad in the front of my truck. Imagine your elbow if you will with your arm being the shaft and you elbow being the joint. When the shaft turns it warbles all angles and is facing resistance from it rubbing on the forward shocks. Can anyone link some information to the replacement process of this? Would you change the whole shaft or repair the joint?
