front clip / body swap ?
twoll86
U.S. Military - Active
caseyville,il
ok i have a 92 explorer that is having trans and wiring issues
i found a 99 complete with a bad engine 4 400 buck i wanted 2 swap that body on to my frame since i have a great engine 488s lockers and 9" of lift
? can it be done?
also i'm one of the odd balls i guess i like the 1st gen front end better what has 2 be done 2 put that front clip on the 2nd gen?
swap from the doors forward including the stucture?
or can i just swap rad supports and go from there
i read some where the wiper cowl was diff is that true?
btw the 99 has the 5r55e i believe and was just rebuilt
I believe the frames are different widths. Check that first.
there the same mounting point except the radiator support which he is changing back to the gen 1 so that dosent matter
a 95-01 explorer 2-door to a 91-94 frame 2-door(same with 4 door to 4 door) is a direct bolt up minus the 2 body mounts on the radiator support.
so as far as the front clip after a swap the rad support is it a bolt on swap?
the rad support is tac welded in and once you change that with the new one then everything will bolt on
ok some one said the the wiper cowl was diff and my hood wouldnt work with out swaping that any trueth in that
OK the 99 sold but found a 5speed 97(even better) with a bad engine does this change anything
the wiper cowls are the same for 89 + rbvs so no
