front brakes "rattling"
87Ranger4me
Eagle Point OR
I have a 87 Ranger XLT. I have been trying to track down this rattling noise coming from under my truck when going over bumpy roads, well the other day while driving with both windows down I discovered that if I apply a little pressure to the brake pedal the noise is completely gone. I remember this same thing happened in an older Ford I had years ago which turned out to be a little plastic sleeve that was missing from the caliper bolts, I replaced them and all was well. Can anybody tell me if there is something similar on my Ranger? If so what are they called so I can replace them. Or could this be something else?
try just jacking it up and manually feeling for something in the brakes, steering or suspension that might be loose. i dont know what it might be but that is the best way to start diagnosing it.
'87 Ranger doesn't have caliper bolts. There is supposed to be anti-rattles clips on each of the inner brake pads. They are usually missing. You can buy them at the parts store though.
Radius arm bushings are the next best guess.
that or the things equivlent to a caliper bolt have came out, I've ahd that happen when not replacing them at brake change time.
