Blueranger99
is it possible to change my open front dif to a limited slip dif? my truck has 3.73s in it.
wont matter if its selectable unless the 4x4 is engaged and the hubs are locked which I wouldnt recommend on pavement
why didnt yall just say that. sounds like a good product.
well since i have a ls in the rear, is there really any need to change anything? for wheeling am i better off with the stock diff. does the front do alot, or is the rear more important? it sounds like there will be problems on road in snow if i do anything with the front. i found in snow that if my rear tires are worn down i slide all over the place, but id i swapped the better tires from the front to the back i got much better traction. i would have thought that with the weight of the motor in the front, that better tires on the front would give me better traction. with the better tires on the back instead of the front i found that i could go through snow in 2wd better than 4wd with the better tires on the front.
