85_Ranger4x4
Wallers in rivers
TRS Event Staff
💻 TRS Socials
OTOTM Winner
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- 5.0L
Like I asked so many others that suggested the distributor must be off one tooth.
Let's say the gear was off one tooth (which it isn't), does this really affect the starting of the engine so long as the rotor is aligned with the corresponding sparkplug (ie; #1) while the engine is on TDC on the compression stroke. If so, why ?
I know it changes the orientation of the body of the distributor in relation to the engine (so that the vacuum advance will be either left or right of the suggested location) but what else does this change. The distributor cam is in a fixed position in relation to the rotor.
As long as you can get whatever post you have set at #1 over where the rotor is setting at TDC it should start. I have mine one tooth off and the wires rotated around one off to compensate so I can get the vacuum advance to work with my Explorer (which were distributorless) front brackets.
You have fuel, you have fire and you have compression... you should have liftoff. Somebody is wacky, is the cam off a tooth from the crank?
Well first of all. My apologies and then my thanks to everyone including Roddy and Sparky that chipped in to help me resolve the no start situation. I am a little embarassed that I wasn't able to figure this out on my own.
