19bonestock88
- Apr 10, 2012
- My credo
- Plane travel? I'll do my flying on the ground, thanks!
so, i have come to an idea of where i want to take my truck, as far as engine goes... i want to find a 2.3 short block and an early 2.3 head(or reuse my 2.0 one) and build a "stage 1.5 engine" out of it. i am hoping for a stage one or two cam, forged pistons, mildly ported head and intake, long tube header, and possibly up to 10 to 1 compression... i might end up going EFI, but could also end up just putting a weber DGEV carb on a ported 2bbl intake(the one off my 2.0).
i know i'm looking at using a pre 94 block and the pre 94 rods are forged, but i have another couple questions since you guys better understand the early engines than almost anyone else.
1. does the roller valvetrain used 89-up bolt into an early SP head? if not, what modification would need to me made? i have heard of conversions but haven't seen one...
2. could the factory EFI be used in conjunction with either the existing (2.0 and early 2.3) ignition system or an MSD ignition(that's box, coil, and dizzy) or would i have to use the TFI that came on an early EFI engine? or possibly i could use MegaSquirt?
3. i thought about building my own long tube header and building it paired pulse style so that i can run a "true" dual exhaust(unless i go with EFI, then it will be a single so that i can run just one O2 sensor) but which cylinders need to be paired? is it 1+4 and 2+3?
