Ok.....I just need the back of the frame. Spare tire area and where bumper bolts on.
The rear section from a 2010 frame would work no matter if its afrom a 2 or 4 wheel drive? Both mine and donor truck are short beds.
The place I can get the frame from is a body shop. They feel it will work since I'm using only the back part.
If I was going to use the front it wouldn't work because the used frame is from a 4X4 ranger and its different in the front.
Its a 3.0 v6 with 138,000 miles. Runs pretty good. My son drives it. It's either that or the 2 shoe express....lol
5 speed trans....he calls it Rita the Ranger.....lol
It's pretty snappy for the miles. We've put a new clutch in it and just put new shackles and mounts for rear leaf springs. Thats when we found the back part of the frame is getting bad. And here in Penn. state inspection won't let it pass so........
Every junk yard I called says they don't know if its the same. But their listings only show entire frames.
Guess measuring would be the best bet to make sure it fits right.
For
