RangerJaynger
I have 2 1996 extended cab rangers,1 is a 4x4, the other is a 2 wheel drive. Unfortunately I got hit hard in the rear on the 4x4 and needs a frame,can I use the 2 wheel drive frame and swap everything over??
@DirtmanIf they are both torsion bar suspensions or both ttb coil spring then essentially yes. If the 2wd is A-arm with torsion springs and the 4wd is ttb with coils then not really.
