lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
Well… the best way to check for soft spots is to go at it with a chipping hammer, one of the cheap ones with the spring for the handle. Makes the process more comfortable like. Because around here you’re gonna want all the comfort you can get after you do this. Totally not kidding. I have successfully swapped the rear frame section on a 2000 Ranger, and also cut and spliced a damaged section forward on the same truck, and did some other frame patches and capped most of the bottom rail under the cab.
I‘ve also had the thrilling opportunity to do a bunch of other frame work on various other trucks. Probably the most brutal was patching behind the steering box on my F-150. I had limited tools and time and money. I got a steel plate big enough and it was a good few hours of tack, heat, beat, tack, weld, heat, beat, tack, weld, repeat… to mold that complex curve.
