harbt95
I've got a 95 splash ex. cab and my frame is kinda rotted behind the rear spring shackles/hangars and really thin in a few spots between the front and rear hangars. I've just picked up the rear half of a 96 ranger frame done all the measurements and everything lines up. I'm a good welder and good with fab work and needed a project for this week. So the front spring hangar snapping this morning gave me a reason to pull the box.
What I'm getting to is, are there any tips you guys that have done frame work can give me?
I'm going to slip the new frame around mine after cutting off the lip on the top so I can slide it over the old frame and bolt everything in place, then weld all the joints not a solid bead but a good staggered pattern maybe 5-3" I will allow time for everything to cool in between beads so not to warp anything. I'm also changing all of the hangars except one that is only a few weeks old.
Will try to get pics and keep the tread updated.
Sent from my iPad using Tapatalk
