Ford Saginaw Power Pump Install??
I cant tell you how much it helps in a stock application because when I swapped to it, it was to run my Full Hydro steering. It will be alot quieter and more consistant regardless.
And yes the original hose bolts up.
so will it help turn my 35's better?
Im going to say yes, because it made my hydro noticably more powerful.
Well, looks like to see about the 2 older pumps that came in today in the junkyard... Time for more upgrading (again). get to see IF these will fit the older style stamped steel brackets for the 2.8/2.9 engines. Will report back by Friday.
